Spokojnie - Panowie z Marketingu już raz próbowali wmówić że octavia to Passant, klasa wyższa itd.. więc Kodiaq w AŚ na 100% będzie testowany z X5,Q7 i na 99% będzie ich zostawiał w skarpetkach :szeroki_usmiech
schemat podłączenia drl octavia rs FL
cholera albo ślepy jestem albo niema zobaczcie:
VCDS Version: Release 11.11.3
Data version: 20120401
Sunday,14,December,2014,21:26:18:32264
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76
VIN: TMBUH61ZX82077632 Mileage: 215520km/133917miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 HB HW: 03G 906 018 HB
Component: R4 2.0l PPD1.2 G 2148
Revision: --H42--- Serial number: SKZ7Z0G4543166
Coding: 0000072
Shop #: WSC 00011 888 81093
VCID: 6CDDDA694F90D69
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 S HW: 1Z0 907 044 S
Component: ClimatronicPQ35 110 0402
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 468948C131BCCC9
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005253195
Coding: E58A8F131004140000110D000000000000097F065C00000000 0000000000
Shop #: WSC 73430 790 00000
VCID: 71E3CB1D68B23B1
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 181007 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 221007 046 0204
Coding: 00471077
Shop #: WSC 73430
4 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 214973 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 214973 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.50 V
ON
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 117
Mileage: 215380 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 11.75 V
OFF
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 214973 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 11.45 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D1387X+
Coding: 0020786
VCID: 6BDFD9754A9ED11
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74EDC20917A00E9
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 842 E HW: 1Z0 920 842 E
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0G4543166
Coding: 0007101
Shop #: WSC 00011 888 96745
VCID: 3973333D7042B31
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 151007F1001366
Coding: E9817F0E4002022302
VCID: 30650E19A338729
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Shop #: WSC 06402 145 00197
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1Z0 919 887 B
Component: Navigation 0412
Coding: 0000002
VCID: 479745C536B6D51
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1203
Coding: 0000244
VCID: 387536394B48AA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 73430 000 90108
VCID: 356B3F0D5C5A571
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283007F3F02850500084F01807C00
Shop #: WSC 00046 412 819200
VCID: 830F11D5C20EB91
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
02483 - Module for Locking of Rear Lid (F327)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 107
Reset counter: 117
Mileage: 212792 km
Time Indication: 0
Date: 2000.00.00
Time: 17:24:49
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000244
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000007
Shop #: WSC 73430 790 08192
VCID: F4ED420997A08E9
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0412
Coding: 0000402
VCID: EBDF5975CA9E511
1 Fault Found:
00879 - Connection to Speaker Front Right
007 - Short to Ground - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377735054656A51
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
VCID: 3D7B272D646A8F1
End ---------------------------------------------------------------------
Tyle, że to jest BCM przedliftowy ( 049 ), więc chyba nie da się go sflashować poliftowym softem ( 087 ), w którym jest pełna obsługa postojowe/dzienne LED.
W tym wypadku najłatwiej było by podłączyć LED-y przez dodatkowy, prosty układzik ( poza BCM-em ) sterowany jedynie sygnałem "postojowych" z BCM ( brak postojowych ---> LED-y świecą pełną mocą jako dzienne; włączone postojowe lub mijania ---> LED-y świecą małą mocą robiąc za pozycyjne ). Trzeba tylko pamiętać, że konieczne będą dodatkowe rezystory ( tzw. kasowniki CAN BUS ) włączone w miejsce żarówek pozycyjnych w lampach "oszukujące" BCM tak, by nie sypał błędami spalonej żarówki pozycyjnej.Jest: Czarna OIIFL Combi 1,8 TSI + DSG
Zamieszczone przez hans860BCM to bornetz to chyba najłatwiej będzie go zwyczajnie wymienić na taki z poliftowego rs'a
ale sam- zapomnij :wink:przyjemność z jazdy zapewnia avant A4 quattro 2,0TFSI
nie wiem czy dobrze kombinuje ale jest mozliwosc wsadzenia BCM sprzed lifta ze swiatlami dziennymi(druga zarowka w przeciwmgielnym) i zastapic je LED nie tracac przeciwmgielnych(poprzez kodowanie ich jako dzienne). Ale wtedy tez trzeba jakos oszukac wywalanie bledu.
I tak jak pisze kowal 2002, mozna zakupic juz gotowe zestawy LED ktore same sie wlaczaja po wlaczeniu silnika Dzialaja chyba na zasadzie porownywania napiecia w ten sposob pomija sie cala elektronike pojazdu.
Ale w tym temacie najwieksza wiedza maja w/w mozgi forumowe
EDIT:
o czyms takim mowilem : http://www.amazon.co.uk/Time-Running.../dp/B0045HYGZ4
Domyslam sie ze bedziesz mogl podpiac oryginalne LED-y do tego i tym samym obejsc elektronike pojazdu. Tylko teraz mnie zastanawia czy musisz uzyc przekaznika czy podpinasz odrazu pod to urzadzenie.Obecnie -> Skoda OCTAVIA II 2.0 FSI
Obecnie -> Seicento 900+LPG
Bylo -> Renault LAGUNA II 1.8
Bylo ->GOLF 3 1.8
Nexus6, nie sądzę że hans860 poleci z Wodzisławia do kowal 2002kliknij 'Lubię to!' www.facebook.com/LukiFanatic a tam O2/O3 RS, O3 RS230, G 6GTI 35, G 7GTI, G 7R, S3, CLA 45 AMG, S5, GT3 RS, Turbo S, M5, RS 7, S 63 AMG, RS6
